The following steps explain how to create a simple menu with SlideShow-Manager.
1. | Start SlideShow-Manager in your AquaSoft SlideShow application via the menu "Wizards".
SlideShow-Manager starts with an empty project.
2. | Add existing slide shows to your project by clicking the button.
In the following dialog you select the slide shows of your choice and click OK.
Your shows will be added to the project.
3. | Now select a template for your project from the template catalog in the lower part of the SlideShow-Manager window.
When you select the template you will see a preview of your menu in the upper part of the window.
Now the finished menu can be saved and burned to be watched on any PC or to be replayed from a DVD on a DVD-player.
