After you created a menu you can export it and burn it to a DVD.
This DVD can then be replayed on a DVD player.
1. | Load or create a new SlideShow-Manager menu.
Click on the entry "Project" in the project tree on the left side of the SlideShow-Manager window. |
2. | Click on the tab "DVD menu". Here you define the settings for the DVD export.
3. | Select the ratio 4:3 if you want to create a DVD for 4:3 - TV.
For widescreen DVDs select the ration 16:9.
Select the video format PAL if the DVD is to be replayed on a TV in Europe.
For replaying it on TVs in the United States select NTSC. |
4. | Activate the check box 'When using "Play all" restart after last title' if you want the replay of all slide shows to be running in an endless loop after clicking the "Play all" button. If you deactivate this option the DVD player will return to the calling menu after the replay of the last show. |
5. | Click the button. |
6. | Select the output format "Video-DVD" and click "Next".
7. | Activate the check box "Burn project" and click the button "Burner settings" to select a burner, and adjust the burning speed, if necessary.
Insert a writable DVD into your DVD burner.
Deactivate the check box left of the drop-down list and click the "Next" button.
8. | In case you inserted an already written DVD-RW, DVD+RW or DVD-RAM, please answer SlideShow-Manager's question regarding the erasure of the medium with "Yes".
Click "Cancel" if you wish to cancel the export now. If you want to use a different medium insert it now and click "No".
After a click on "Yes" SlideShow-Manager will erase your DVD.
Click "OK" after the erasure has been completed. |
9. | SlideShow-Manager is now ready for the export. Click the "Export project" button.
The exporting process can take some time depending on the number and size of the slide shows. |
10. | Click "OK" after the export has been completed. |
