Welcome to AquaSoft SlideShow-Manager |
With AquaSoft SlideShow-Manager creating sophisticated interactive DVD and PC menus from your slide shows by using templates is a child's play. You can use the templates that are included with the the application, load new ones from the Download Center or design own templates for your menus using the integrated Editor. The new AquaSoft Effect System is available for designing your templates. Provide your templates with a title page and an end page, and add background music of your choice. SlideShow-Manager takes into consideration the structure of your slide shows and also allows to create a structure of chapters.
Watch your menus directly on your PC, or burn them to CD or DVD and replay them on a different PC. Create DVDs in 4:3 or 16:9 format which you then can replay in every DVD player or on PC.
We hope you will enjoy working with AquaSoft SlideShow-Manager. |
Copyright © AquaSoft ® GmbH 1999-2015 www.aquasoft.net |
