After you created a menu you can export it and burn it to a CD or DVD, together with all slide shows used.
These CDs or DVDs can be replayed on any PC.
1. | Load or create a new SlideShow-Manager menu.
Click on the entry "Project" in the project tree on the left side of the SlideShow-Manager window. |
2. | Click on the tab "PC menu". Here you define the settings for the PC export.
3. | In the area "Window" select one of the pre-defines resolutions or type in the width and height of your choice.
The finished menu will later be replayed in the resolution you defined here.
Activate "Show button hints" if you wish to see hints about the functionality of a button later when moving over it with the mouse. |
4. | Click the button. |
5. | Select the output format "PC menu" and click the "Next" button.
6. | Activate the check box "Burn project" and click the button "Burner settings" to select a burner, and adjust the burning speed, if necessary.
Insert a writable CD or DVD into your burner.
Deactivate the check box left of the drop-down list and click the "Next" button.
7. | In case you inserted an already written CD-RW, DVD-RW, DVD+RW or DVD-RAM, please answer SlideShow-Manager's question regarding the erasure of the medium with "Yes".
Click "Cancel" if you wish to cancel the export now. If you want to use a different medium insert it now and click "No".
After a click on "Yes" SlideShow-Manager will erase your CD or DVD.
Click "OK" after the erasure has been completed. |
8. | SlideShow-Manager is now ready for the export. Click the "Export project" button. |
9. | Click "OK" after the export has been completed. |
