Many templates that you can download from the Download Center allow to be customized to your liking with only little effort.
SlideShow-Manager templates can contain variables that you can replace with your own contents in the Customization.
1. | To customize your project click on "Project" in the project tree on the left side of the SlideShow-Manager window.
2. | Click on the tab "Customization".
Now you can see a list of variables that can be used in your project.
SlideShow-Manager assembles this list from all variables of the template that are used in the project.
The variables of most templates already have default values. Edit these values according to your needs.
