3D cuboid
Navigation:  Object effects > 3D object effects
3D cuboid
The cuboid has six sides, each of which can be filled with images, videos or text. The side proportions can  be different in the 3D cuboid - in contrast to the 3D cube, whose sides are all square. In addition, each side in the cuboid can be filled with a color or a color fill can be placed behind the content.
Settings for effect
Settings 3D cuboid
Settings for 3D cuboid
With acceleration,  you decide whether the cube should move at a constant speed (select "none") or appear to accelerate at the beginning and/or end.
Increase the display duration of all images in the effect to make the cuboid animation run longer overall.
As long as there are no photos or videos in the effect areas, the six sides of the cuboid are filled with colors. The color can be changed using the color selector. It is also possible to select a transparent color.
To ensure that inserted images fill the pages completely, select Aspect ratio: Crop in the image properties. If the image is not cropped, it will be fitted onto the cuboid page while retaining its aspect ratio; uncovered areas will be filled with the set color.
You can influence the appearance of the cuboid via the Width, Height and Depth settings.
You can determine which view or side of the cube is shown first by changing the X/Y/Z values at the start position.
You can influence the rotation animation (frequency of rotations and direction) using the Angle, Rotations per second or Number of rotations modes. If all values for the X, Y and Z axes are set to 0, no animation takes place. Use minus values to force counter-rotations.
To make the effect work for you, we recommend using the None fade-in for all images in the effect or an identical fade-in for all six images. To assign the same fade-in to all images at once, select all images while holding down the  CTRL  key. Then select the desired fade-in in the properties.
Increase the display duration of all images in the effect to make the cube animation run longer overall.
To quickly adjust the display duration of the effect (and therefore the duration of all internal objects at the same time), use the Intelligent scaling at the top of the properties.
Size and position of the 3D cube
Select the effect frame on the Timeline to change the position of the cuboid. Then move the object in the Layout designer in motion path mode. The cuboid can also be given a motion path.
Design view
3D cubiod with front image and text on five sides
3D cubiod with front image and text on five sides in Layout designer
