<< Click to Display Table of Contents >> Utilize the wizard |
The Smart template wizard includes a number of Smart templates to facilitate the creation of your project.
You can select images and music from which, in combination with a style, a project will be created. All this is done automatically. You only need to add pictures and music.
Via File / New / Use Smart template wizard you can open the Smart template wizard. Click on Next to start designing the project.
![]() Adding images Next, add the images via the Plus icon. Then click on Next. |
![]() Adding music If you would like to use background music in your project, you can add this via the Plus icon. Then click on Next. |
![]() Choosing a template or watching a preview Here you can choose a style of template for your project. By clicking the button Start preview you will be able to get a sense of the style sheet. Then click on Next. |
![]() Entering your own labeling Depending on the template, you have the option to personalize it by adding, for example, titles, subtitles and credits, among other things. Then click on Next. |
![]() Output options Now you can decide what the next step should be. Editing your project:In order to edit, open the style sheet in AquaSoft Stages. It is now possible to make individual adjustments. Burning a PC presentation onto a CDThis option opens the CD/DVD and archive wizard. You can burn the project onto a CD/DVD or prepare to pass on. The burned CD / DVD can be played back on a PC (not on a DVD player). Burning a video to Blu-ray, DVD or (S)VCD:This option opens the Video Wizard. Here you can burn your project onto a Blu-ray or DVD. You must have already converted the project into a video. This process may take some time to complete. Then the burned Blu-ray or DVD can be played back with a BR or DVD player. |
