<< Click to Display Table of Contents >> Smarties and Media Bricks |
In Stages you will find in the Toolbox Smarties and Media Bricks that can help you design projects quickly. With the Smarties, you can achieve everything that you could also implement with individual program objects (standard elements and certain effects). However, the smart templates already combine several components (e.g. background + foreground + text) and possible settings and effects in one object. Find out morein the Smarties chapter. The Media Bricks contain templates for animated intros, outros, texts and call-to-action buttons. The media modules are particularly suitable for short projects that are to be shared as videos on social platforms. Combine the objects with each other or with the classic standard objects as required. |
