Live effects / Video effects
Navigation:
Live effects in the Toolbox
The Live effects can be found in theToolbox under the Objects tab .
In the AquaSoft Video Vision there are a total of 31 live effects. In AquaSoft Stages, in addition to the 31 live effects, there is the Chroma Key effect.
In AquaSoft Photo Vision , the Color shift, Color effects, LUT, Blur effect, Sharpen, Old fashioned movie and Tonal correction are available.
Live effects modify the appearance of the objects you drag into the effect.
1 Using the Live effects
Drag an effect from the Toolbox to the Timeline. An empty box will appear into which you can insert your photos or videos. Once you have inserted the content, click on the colored frame of the effect. In the Properties area, set the parameters for the effect.
You can also access Mini templates for some effects via the Properties. These are variants of the effect with specific default settings. Open the mini-template gallery and select an effect variant by clicking on it. The effect settings can be adjusted further if required and also saved as your own mini-template.
2 Post-processing
Some effects offer the option of post-processing, in which case the effect affects everything visible before the effect. Everything within the effect frame is then not visible. If the effect frame is in the track underneath the objects, the effect lasts as long as set under "Duration". If the content track of the effect is empty, post-processing is automatically active.
3 Removing a Live effect
To remove a live effect from your images or videos, right-click on the effect in the Timeline and select Remove effect.
