<< Click to Display Table of Contents >> Preparations |
Microsoft has built a so-called ransomware protection into Windows 10. When this is activated, Microsoft blocks some folders from being accessed by almost any program. By default, your own and public folders for documents, pictures, music and videos, as well as your favorites are protected. You can't unprotect these without disabling it altogether. However, you can include folders that you want to protect yourself. The Temp directory and the application data must not be protected, since programs store data necessary for the process or user-specific data there. If ransomware protection is active, AquaSoft Vision must be unlocked to access protected folders in order to function properly. |
Number of picturesIf the presentation is varied and exciting, friends or family will agree that time is relative. So the number of pictures is also a completely subjective decision. The better you "write the script", the better you will know how many pictures to show. Before you design a presentation, ask yourself the following questions: •Is there enough variety among the images, the videos, and the music? •Are the images and videos of appropriate quality? •Have I designed the presentation so that there are moments for the viewer to be excited and surprised? With a good amount of preparation, you have already made a picture selection in which motifs are not repeated and the shots are interesting and varied. |
Sorting imagesIn order to achieve a good result quickly and effectively, you can make some preparations in advance. It makes sense to create a directory and possibly divide it into subdirectories. In these subdirectories you can store your images, sorted according to your own criteria. Also, if you still want to rename the images, you should do this now. If the images are inserted first and then renamed or moved, they will no longer be displayed in the project. |
Organize your images before you start creating the project. When you insert the images, they are not saved again. Only the reference to the location where the images are stored is saved. If the images are moved to another folder or renamed, they can no longer be retrieved using the reference. |
AquaSoft Vision and Stages support the following file types, among others:
Image formats |
Video formats |
AquaSoft image container (*.asimage) |
Animated GIF (*.gif)
Always insert GIF files via the Video object. If the display duration cannot be detected automatically, you may need to adjust it. If you want to display the animation longer, set None under Fade In, copy the Video object, and paste it several times until you reach the desired length. Alternatively, use the GIF in the Repeat effect. To use Heic and Heif images, your Windows operating system requires a corresponding Heif image extension that is not installed by default. |
Sound formats Advanced Audio Coding (*.aac) |
