Rotate text
Navigation:  Texts and labels
Rotate text
1 Rotate text in the Layout designer
Insert an image and enter a caption in the Object settings window under the Text tab. Your text now appears on the image and is surrounded by a dashed frame. Outside the frame, centered above the text, is a dot. Click on the dot and hold down the mouse button. The mouse pointer appears as a crosshair. Now rotate the mouse: you will see how the text rotates.
Once the text has reached the desired position, you can release the mouse. A number appears next to the point you click to rotate the text. This indicates the angle of the rotation in degrees.
2 Specify angle of rotation
Manual input
Manual input
If you want to specify the angle as precisely as possible, use the Manual input. You call this up by pressing the  Ctrl  +  M  keys simultaneously. Under Rotation / Angle you can now enter the value yourself.
symbol-project
Under File / Open / Sample project you will find a text animation "Text with momentum" in which the text rotation has been applied. If you wish, you can change the text, copy the animation and paste it into your project.
