<< Click to Display Table of Contents >> Creating a CD image for the PC |
![]() Settings for PC Menü If you have created a menu you can create a CD image which you can later burn yourself. CDs, that you can burn with the image can be replayed on your PC. 1 Load or create a new menu. Click on the Project entry on the left side of the Menu Wizard window in the project tree. 2 Click on the PC menu tab. Here you can make settings for the export. 3 In the Window section, select one of the preset resolutions or enter your own resolution. 4 Click on the button |
![]() Select PC menu 5 Select the output format PC Menu and click Next. |
![]() Create CD-image (ISO) 6 Check the checkbox to the left of the drop-down list and uncheck the Burn project checkbox. 7 The Menu Wizard is now ready for export. Click on the Export project button. 8 After finishing the export, click OK. |
