<< Click to Display Table of Contents >> Exporting a menu to a directory |
![]() Settings for PC Menü Once you have created a menu, you can export it with all the projects and images used to a folder and burn, archive or view it later. 1 Load or create a new menu. Click on the Project entry on the left side of the Menu Wizard window in the project tree. 2 Click on the PC menu tab. Here you can make settings for the export. 3 In the Window section, select one of the preset resolutions or enter your own resolution. 4 Click on the button |
![]() Select PC menu 5 Select the output format PC menu and click Next. |
![]() Copy project to a directory 6 Check the checkbox to the left of the drop-down list and uncheck the Burn project checkbox. 7 The Menu Wizard is now ready for export. Click on the Export project button. 8 After finishing the export, click OK. |
