<< Click to Display Table of Contents >> Creating a simple menu |
The following steps explain how you can create a simple menu using the Menu Wizard.
1.In your AquaSoft Video Vision or STAGES start the Menu Wizard via the “Wizards” menu. The Menu Wizard begins with an empty menu.
2.Add projects to your menu by clicking on the plus icon. In the dialog box that appears, select the desired project and click OK. Your projects are added to the menu.
3.Now select a template for your project in the template catalog at the bottom section of the Menu Wizard window. When you select a template, at the top of the screen you will see a preview of your menu.
You can now burn the completed menu for viewing on any PC, or as a DVD for playback on a DVD player.
