Legend / Symbols
Navigation:  General information
Legend / Symbols
symbol-video
Features that are tagged with this image are explained in more detail in a video.
You will find the short link to the video behind this symbol.
symbol-hint
The bell indicates particularly important information. This should not be overlooked under any circumstances.
The light bulb displays additional tips and hints, including additional information that you can find in our AquaSoft Blog.
symbol-project
Sections marked with this symbol contain references to a sample project. The sample project can help you better understand a feature and give you valuable design ideas.
