"Shared device access" error message
Navigation:
Return to chapter overview
When attempting to burn, an error report titled "Shared Device Access" appears.
Solution:
AquaSoft Vision or Stages wants to burn, another program or process on your computer prevents this. This could be, for example, another burning program that has noticed that a blank disc has been inserted or a process that switches on when a rewritable blank disc is inserted. You may be able to use the Windows task manager to find out which process was started when the error occurred. You can call the task manager with the key combination  CTRL  +  ALT  +  DEL . You can then terminate the problematic process manually via the task manager. After that you should be able to ignore the error message ("Continue" click).
