You have not selected a burner
Navigation:
Return to chapter overview
When you try to start burning in the Video Wizard by clicking Next, the message "You have not selected a burner" appears.
Solution:
In the Video Wizard window, click the color-linked word Change. Now select the burner you want to use for burning in the CD/DVD/BR burner item in the program's burning settings.
You can also access this setting option at any time via Extras > Program settings > CD/DVD/BD burner.
