Error message "You do not have a blank disc inserted"
Navigation:
Return to chapter overview
When trying to burn, the program reports "You do not have a blank disc inserted" even though there is already a disc in the burner drawer.
Solution:
1.Please use another blank
Possibly the blank used has already been written on or is damaged, for example, due to incorrect storage.
2.Was the correct type of blank inserted?
Use blank types and blank brands supported by your recorder.
DVD: DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
BR: BD-R, BD-RE
