<< Click to Display Table of Contents >> User interface selection |
You can choose between the following eight skins for the user interface. When you start the program for the first time, the skin selection depends on the color mode of your Windows settings.
•Dark •Medium dark •Medium light •Light |
•Midnight (Default for dark design) •Slate •Grayish blue •Light grayish blue (Default for light design) |
You can change your selection at any time via Extras / Program settings / User interface. You can also decide whether the icons and symbols of the user interface should be displayed in color, monochrome or black respectively white depending on the skin color.
After making your selection, you will need to restart the software for the changes to take effect.
