<< Click to Display Table of Contents >> Change playback speed |
![]() Change playback speed In the properties window, you will find the item playback speed. For a slower video, enter a value <100%. If you wish your video to play at half speed, for example, enter the value 50%. To make your video play more quickly, enter a value >100%. For example, 200% will double the speed of the video. |
2. Dynamically accelerate or decelerate your video in the keyframe track
![]() Curve for playback speed in the timeline
In stages you can have varying speeds for your video object. Set the maximum value of the playback speed in the properties window. |
