<< Click to Display Table of Contents >> Template editor |
In order to be able to create or edit templates, the developer mode must be turned on. You can activate this in Video Vision and Stages via “extras / developer mode". |
The template editor enables you to create your own templates and edit those that exist already.
You will find a number of tools to make your template. Add images, texts, buttons and project placeholders. On the right side of the editor window you can edit the properties of a selected object.
Also observe the design guidelines for templates and the information on the types of templates in the Menu Wizard.
