<< Click to Display Table of Contents >> How to |
Here is a series of instructions that working with the Menu Wizard will make easier.
Read here how you
•Create a menu with separate chapters
•Apply templates to the project and subchapters
If you have designed a menu, you can burn it:
•Burn a menu for playback on PC
•Burn a menu for playback with a DVD player
In addition, you can also use one of the other export options:
•The exporting of a menu into a folder
•The archiving of a menu as a ZIP file
