<< Click to Display Table of Contents >> Legend / Symbols |
Features that are tagged with this image are explained in more detail in a video. |
The bell indicates particularly important information. This should not be overlooked under any circumstances. |
The light bulb displays additional tips and hints, including additional information that you can find in our AquaSoft Blog. |
Sections marked with this symbol contain references to a sample project. The sample project can help you better understand a feature and give you valuable design ideas. |
