<< Click to Display Table of Contents >> Different pieces of music for several groups of images |
Set end position of the title
If you have arranged your images according to different sense units or if you want to play a suitable title for a new image group, you can change the music tracks to match the image sequence.
First insert your images. Set the duration of the respective image group and insert the background music.
Click on the title and enter the duration of your image group under End position.
Different titles for different groups of images
